Rate of change UDT
complete
Madison Knowles
A UDT definition that calculates the rate of change for a particular analog value.
Use this formula as guidance:
The UDT should contain an OPC tag with a configurable OPC Item Path and the calculated RateOfChange value.
Log In
Madison Knowles
marked this post as
complete
Madison Knowles
This resource has been completed by Arnaud De Clerck and can be found here: https://inductiveautomation.com/exchange/2233/overview Thank you for your contribution to the Ignition Exchange!
Madison Knowles
Hi Arnaud De Clerck, it should be calculated at a fixed rate.
A
Arnaud De Clerck
Hi Madison, Should the rate of change be calculated at any value change or at a fixed rate ?
Madison Knowles
marked this post as
open
