Allow Project Minimum/Maximum Size to be Modified from a Runtime Client.
complete
l
leah@tamaki.co.nz
There are a few instances where this would be extremely helpful, esp when projects have both high and low resolution clients. For a 1920 x 1080 project, the minimum size usually needs to be 1920 x 1080 so that all office-clients with less resolution get scroll bars and can see the entire screen. If there are field-clients that are low resolution and only have access to a few screens, then it would be great to modify the minimum size for that particular client since that's the only way to get rid of the scroll bars. Essentially this gives us another option instead of creating a separate project and using global templates.
Log In
pscott
updated the status to
complete
Marking this as complete, with the caveat that you should open a separate response if we're misunderstanding something.
In Vision, scrollbar control is generally handled via Component Layout. In this case, the minimum size should be set to the smallest field device dimensions, not the office dimensions (assuming the field devices have less resolution than the office devices).
In Perspective, the breakpoint container was designed specifically for this use case.
awalker
under review
