Symptom: Table object's selection is stuck after a refresh in the browser. Selected row and selected dataset holds the last value from before the refresh, and resetting these properties does not work.
Setup: Table object, query binding that returned dataset with 3 columns. Row selection and multiple interval selection are enabled. Four columns are configured in column properties. The fourth uses a custom view to show a calculated status, with 'field' set to 'column_4', which does not exist in the dataset. The view has a parameters bound to the implicit 'value' and 'rowData'.
Suspicion: Table object fails when 'value' is null/undefined for a column whose field isn’t in the dataset. This seems to leave the table’s selection state stuck after a refresh.
