Bug: Perspective session can get stuck on loading screen in redundant setups ("Initializing client...")
B
Bjornar Alvestad
System info:
- Ignition 8.1.35 (running in docker container)
- Redundant gateway setup (cold, recovery mode manual)
- Browser: Chromium 112.0.5615.165 and 123.0.6312.122
How to reproduce:
- Restart both Ignition servers.
- Open one perspective session on Master and one on Backup right after it becomes running, but before it becomes active.
Both perspective sessions will be stuck on loading screen now, but when Master becomes active, that perspective session will continue loading.
The one towards the gateway that did not go active will be stuck until someone presses refresh. After refreshing it will manage to load the perspective session from the gateway that is not active, which will then successfully redirect it back to the active one.
This is an issue for high availability systems that are required to start up by them selves without any user interaction, since some HMI clients could end up getting stuck in various different scenarios.
Expected behavior:
The session towards the gateway that did not become active should also continue loading (and then redirect to the active one), without the page needing to be refreshed.
Related feature request:
A related feature request that could help work around this issue for initial startup would be if StatusPing page also included additional info on if gateway is active, and not just if it is running.
That would also enable the creation of more robust custom redirect scripts. And help where other systems for some reason would like to know which gateway to try and communicate to.
This has been posted as a separate feature request for adding Activity Level to StatusPing page
Log In
