Drag on empty space, in designer, creates a pipe
L
Leidulf Eike
In the designer (perspective) if you have used the pipe tools, since opening designer, and later, using the Component Selection Tool, drag over empty space as if to select components, but do not select any. The designer will change to the pipe tool and create a starting point for a pipe at the cursor.
This is pretty annoying since you then have to undo the pipe and switch back to Component Selection Tool.
Log In
