Grid and snapping in Perspective Coordinate Container
B
Brian Stilson
It'd be really nice to be able to set up a grid in a Coordinate container and have all objects snap to it instead of using the object alignment tools. The object alignment tools are a pain to use. They often misalign objects by making a "mistake" as to which feature in another object they want to align it to. The whole thing is "too automatic." Just having a simple grid setup where you can snap objects to it would make it a lot easier to build quality layouts with perfect alignment. Even the arrange features where you can stack horizontally or vertically often looks bad.
Log In
Activity Feed
Sort by
R
Rickard Moberg
Agree! Would be really nice to toggle on snapping to position coordinates that follow preference settings. E.g. position x and y can only take values dividable by 1, or 2, or 0.5, etc.
This would only apply to the object that you are moving, so you could then enter with high resolution if you'd like, and if you are moving a group of object, then there must be one that follows this principle and the rest would move in proportion to original position to the main object.
