pscott
updated the status to
closed
Indeed, this would be awesome, but most likely will not happen.
You may have noticed that the SDK is not part of the Ignition User Manual. There are many reasons for this, but a major reason is that the SDK is unsupported. The SDK is a fantastic tool, yet its use requires a very particular set of skills; a skill set that the rest of Ignition does not require.
Incorporating the SDK on IU would blur the lines between supported versus unsupported, which we're not comfortable with. Sadly, we're going to have to close this request. A video library demonstrating how to use the SDK would be fantastic. However, if we ever did create such a library, it most likely would not be a part of IU.
Z
Zack Scriven
pscott: Okay YouTube Channel it is then. :)
awalker
under review
J
Josh Dunstan
It's not on IU yet but you can use the new section on the v7.8 user manual..
