keep tag history values linked when tags are moved
S
Steve Perry
Not sure if this has been fixed recently or not.
In the "tag browser in Designer, if you move tags from one folder to another, the history values for the tags do not remain linked to the tag. It looks like the tag history vanishes, but I am told that it could be re-linked to the tags.
When tags are moved in the "tag browser" tool, the default behavior should be to keep the "tag history values" linked to the tags.
Log In
A
Anthony Ho
It is going to be 10-year anniversary of this request. And it is very important to have. Any progress is made?
N
Nick Minchin
Add removing history when tags are deleted as well, but this should have a prompt which defaults to No
N
Nick Minchin
An improvement (imo) to this suggestion, is for the Designer to ask you if you want to keep (re-link) the history for the tags you're moving, or otherwise to remove the link. Sometimes, you actually mightn't want to re-link the history.
K
Kory Koziar
This is a feature that needs to be implemented. I have a procedure to do this (to re-map the sqlth_te tables), but when dealing with 60,000+ tags being moved, it is lengthy (and risky).
N
Nick Minchin
This would be super handy to have
