Parameterize Alarm Names
complete
J
Joseph Martell
Currently alarm names cannot be parameterized. This means that I have to go through the trouble of manually adding alarms to each and every UDT instance throughout my system. What makes this worse is when I am doing complicated configurations like binding priority, callout group, and alarm message to other UDT member tags. Because I cannot parameterize the alarm name I cannot define the tag in my UDT with all of the binding set up. I have to manually go through each and every tag in my entire system adding alarms and manually binding all of those properties. It is only 3 or 4 properties, but if you have 1100 alarms that adds up to days of work.
Log In
P
Paul Griffith
updated the status to
complete
Alarm names cannot be parameterized, but the new 'label' field added to alarms in 7.9.10 can be bound, and will be used instead of the name for display purposes.
R
Rakiduamn SRL
I have serious problems to solve this issue for each UDT instance. PLEASE DO THIS!
j
jacky.winters@spsx.com
can't see why this does not have more votes... this is indeed a busy-work task. please PLEASE do this!
