When moving and resizing objects inside a coordinate container in a Perspective view, I can use the shift key to resize the object with the keyboard arrows versus just moving it. The alt key lets you take bigger steps and the control key lets you change the direction of the resize.
It'd be great if they were the same in the Drawing Editor, currently it uses the alt key to take bigger steps when moving but if you use the shift key to resize it uses the control key to take bigger steps and there's no way to change which direction you're sizing.
Having a key you can hold down and keep the aspect ratio is pretty standard. You've drawn an object made of a bunch of other objects, grouped it, got it the way you want it and now you just want to make it a little bigger/smaller. It looks like there's no way to do this in Perspective or the new Drawing Editor.
Dragging the selection box, the behavior seems to be the same in Perspective Designer and new Drawing Editor, it'd just be nice to have keys to modify the type of box and the ability to start the selection box wherever you want. Inevitably there's always something in the way and you can't start the box where you would like or starting the selection box from the left side is clear and dragging it over what you want but then it's not the type of selection box you want to use.
When copying multiple objects on top of each other it likes to change the layer order so when you paste it you keep having to change the layer order and move one object on top of the other.
The original objects on the left have the dark gray shading on top but when those are selected and copied with a selection window then it keeps moving the dark gray object to the background. If you can manually select each object in a particular order it'll stay the same when pasted.
Another nice to have key modifiers on object rotation where it can snap to 0°, 90°, 180° and so on.
