Predefined argument selections for parameters
planned
c
chris.m
It'd be great to be able to assign a drop down list of predefined arguments to set for custom parameters on templates and windows. SO when a template is selected in the designer the user can only select from the list of arguments for that parameter, or perhaps have the list but also be able to enter another parameter as you already can now. Similar to how a user can select colors from the color picker for color parameters.
Example being I have a custom parameter on a template which is a double. And this parameter is binding to the angle parameter of a graphic inside the template, then rather having the designer enter anything from 0 - 360, they can select from a drop down "up, left, down, right", which would correlate to "0, 270, 180, 90".
A way to help conform designs to internal standards.
Log In
P
Paul Griffith
Merged in a post:
view parameters, dropdown list
K
Kevin Verschueren
With an embedded view, it would be nice to be able to create a drop-down list for the necessary parameters.
For example, if you create a typical and you have 2 options as parameter, it would be useful to be able to display this via a drop-down list so that the user does not have to open the embedded view to know what he can enter.
B
Brandon Tanner
Is there any update on this?
P
Paul Griffith
updated the status to
planned
Something along these lines is planned for Perspective, though not Vision (currently).
B
Ben Schroeder
Paul Griffith: I'd put a vote in for something like this in Vision. that would help with our objects for styling etc... and not be reliant on the engineer or end user to make sure they type in the correct parameter.
