Previously selected properties persist in Tag and UDT JSON files
M
Marc Dobson
For example, a Memory tag has the field "value". If I override that value to from a default value of 10 to 100 and apply, then I decide I want to override the tag to be an expression tag, so I do and apply the change. Because the expression tag doesn't have the field "value" the value key remains unused/unchanged within the json data. This is undesirable because we are doing json dif's between the UDT instances and the UDT definitions at our sites to assess the validity of overrides implemented by our engineers. Ideally the only data that would exist in a UDT definition or UDT Instance json data would be the data that is visibly selected within the tag editor within the designer. Does Inductive have any plans to address the functionality as it currently stands to streamline/declutter the json data?
See Support Ticket #205168 for further details.
Log In
