Role Based Access to Client Launcher
D
Dion Botha
There should be a property in Gateway Settings for Client Launcher Role(s) and if you don't have one of these roles you cannot open the Client Launcher. We can then give all our developers this role which they use on client machines to create desktop shortcuts for end users.
Log In
D
Dion Botha
Another idea would be to have a property in the gateway settings to disable/enable client launcher authentication
D
Dion Botha
Even better - needing required roles to access the ‘Select Applications’ side (which comes after a gateway is selected) of the client launcher?
D
Dion Botha
Alternitively, needing required roles to only access the 'Add Application(s)' side of the client launcher? More info here: https://forum.inductiveautomation.com/t/launch-client-without-clent-launcher/23136/38
