Sync View parameters to Embedded Views
complete
n
nick.minchin@gotosage.com
Currently, if you embed a View and then change the View's params, they're not automatically added into each instance of where it's embedded. Please sync these up
Log In
B
Bart van Deurzen
I am not sure what "complete" means. I am working with version 8.1.9 and I can see the function to "Sync Params", but the parameters I have deleted from the embedded view just keep popping up. Perhaps the "fix" was only to make ADDED parameters show up? It works for adding, but I think it should also work for deleting.
P
Paul Griffith
Merged in a post:
Perspective View Parameter Update
m
michael.walter
Would request that functionality be made to automatically add or remove (preferably add) any parameters automatically to any embedded view instances where its used. We update views all the time with new functionality (and parameters) and then have to go to every single existing instance of the embedded view to add in the parameter.
P
Paul Griffith
marked this post as
complete
In 8.1.4, there will be a right click menu option available to sync parameters from the source view into the embedding component(s).
P
Paul Griffith
Merged in a post:
Show all View parameters in embedded view components
P
Pietro A
When a View is put in an Embedded View component the parameters of the View are not automatically populated in the param property. Instead we have to add them manually. I am suggesting when a view path on an Embedded Component is selected, the params property should automatically be populated.
P
Paul Griffith
Merged in a post:
View paramter propagation in Perspective
A
Ali Etezadkhah
Please consider adding the capability to allow newly added view parameters to be propagated down to all of its embedded instances. This would bring it to parity with the Widget function in Vision.
