Tag Browser: Add options to copy all config into JSON
n
nick.minchin@gotosage.com
- For tags part of a UDT instance, “Copy JSON (All Non-default)” which would copy all non-default values for that tag. At the moment, we only get the non-default config relative to the UDT instance (i.e. we only get the name, data type, and any overridden properties on that tag, we don’t get the non-default properties configured on that tag within the UDT definition). Parameters should be applied in the copied JSON. This would be useful if you wanted to create a new standard tag from a UDT tag or when converting a UDT instance from a UDT into standard tags (for example when you realise that using a UDT will be more work than it’s worth as you will have too many variations)
- Add an option to “Copy JSON (All, including defaults)” which would copy the tags and include all default values.This would be more useful for documentation more than anything else.
More details here:
Log In
