Sometimes, a template must be used in multiple projects on a single Ignition server (gateway). Inside the project where the template is created, we can presently right-click and "send to" in order to COPY the template to the other projects. However, no link between the template COPIES is maintained, so changing the template in one of the projects does not automatically change the template in the other projects.
Would be great to have a "shared templates" or "global template library" on each Ignition server (gateway), with each project able to reference and use the "shared templates".
