General feedback
closed
T
Tom Stevic
I have two suggestions you may want to consider.
1: Synchronize the volume in the videos.
2: Some of the videos use database tables and such, but did not describe the construction of said tables.
Log In
pscott
marked this post as
closed
Closing the idea since the two are more or less in progress or handled.
1) Regarding the volume, yes, that's something we're more aware of nowadays. As we replace the older videos, those volume issues should be handled.
2) We do describe the tables in the user manual, which feels more appropriate for that type of content: https://docs.inductiveautomation.com/display/DOC81/Ignition+Database+Table+Reference
A
Alex Marks
There is one video that describes how to use MySQL Workbench to create the database. For the most part, the tables that are used within the database are auto-generated by Ignition (tag history, for example). The other examples are going to be very project-specific and, most likely, you would need more in-depth knowledge of SQL to set up. The intent of these videos is not to teach SQL, but rather to show features of Ignition and SQL integration, should you need it.
